Ir para o conteúdo principal
Screen Assembly Removal
O que você precisa
  1. Screen Assembly Removal, Turn off the watch: passo 1, imagem 1 %32 Screen Assembly Removal, Turn off the watch: passo 1, imagem 2 %32
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Screen Assembly Removal, Remove the rear screws: passo 2, imagem 1 %32
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Screen Assembly Removal, Separate the back cover from the housing: passo 3, imagem 1 %32 Screen Assembly Removal, Separate the back cover from the housing: passo 3, imagem 2 %32 Screen Assembly Removal, Separate the back cover from the housing: passo 3, imagem 3 %32
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Screen Assembly Removal, Disconnect the sensor array: passo 4, imagem 1 %32 Screen Assembly Removal, Disconnect the sensor array: passo 4, imagem 2 %32
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Screen Assembly Removal, Remove the back cover: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Screen Assembly Removal, Disconnect the display and the mic array: passo 6, imagem 1 %32 Screen Assembly Removal, Disconnect the display and the mic array: passo 6, imagem 2 %32 Screen Assembly Removal, Disconnect the display and the mic array: passo 6, imagem 3 %32
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Screen Assembly Removal, Undo the mic tape: passo 7, imagem 1 %32 Screen Assembly Removal, Undo the mic tape: passo 7, imagem 2 %32 Screen Assembly Removal, Undo the mic tape: passo 7, imagem 3 %32
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Screen Assembly Removal, Lift the core assembly: passo 8, imagem 1 %32 Screen Assembly Removal, Lift the core assembly: passo 8, imagem 2 %32
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Screen Assembly Removal, Remove the core assembly: passo 9, imagem 1 %32 Screen Assembly Removal, Remove the core assembly: passo 9, imagem 2 %32 Screen Assembly Removal, Remove the core assembly: passo 9, imagem 3 %32
    • Lift out and remove the core assembly.
  10. Screen Assembly Removal, Loosen the mic: passo 10, imagem 1 %32 Screen Assembly Removal, Loosen the mic: passo 10, imagem 2 %32
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
  11. Screen Assembly Removal, Free the barometric sensor: passo 11, imagem 1 %32 Screen Assembly Removal, Free the barometric sensor: passo 11, imagem 2 %32
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Screen Assembly Removal, Remove the mic array: passo 12, imagem 1 %32
    • Carefully remove the microphone and barometric sensor array from the frame.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Tobias Isakeit
Membro desde: 03/31/14
129.593 Reputação
Autoria de 189 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 703
