Ir para o conteúdo principal
Screen Alignment Process
  1. Screen Alignment Process, Screen Alignment Process: passo 1, imagem 1 %32
    • With the phone powered on and at the home screen, tap "Start".
  2. Screen Alignment Process: passo 2, imagem 1 %32
    • Tap "Settings".
  3. Screen Alignment Process: passo 3, imagem 1 %32
    • Tap "System".
  4. Screen Alignment Process: passo 4, imagem 1 %32
    • Tap "Screen".
  5. Screen Alignment Process: passo 5, imagem 1 %32
    • Now tap "Align Screen". This will initiate the Screen Alignment Process on your phone. Follow the instructions on the screen.
    • The Screen Alignment Process must be completed with the phone stylus only. This will ensure proper alignment of the phone's screen.
Conclusão
Your HTC Fortress' screen is now properly aligned.
Lucas David
Membro desde: 04/19/13
540 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 4-13, Maness Spring 2013 Membro de Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 39
Ao todo: 8,666
