Ir para o conteúdo principal
Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement
O que você precisa
  1. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement, Training Wheels: passo 1, imagem 1 %32
    • Flip the bike upside-down for stability.
  2. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 2, imagem 1 %32 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 2, imagem 2 %32 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 2, imagem 3 %32
    • Use a 15mm socket wrench, and remove the wheel arm bolt securing the wheel arm.
    • Remove the damaged wheel arm.
  3. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 3, imagem 1 %32 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 3, imagem 2 %32 Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 3, imagem 3 %32
    • To replace a damaged wheel, use a 13 mm socket and a Phillips screwdriver, and remove the wheel screw fastening the wheel to the wheel arm.
    • The screw may be hidden behind the bike's design theme. If this is the case, poke through the label to reach the screw in the center of the wheel.
    • Replace the damaged wheel and secure it with the screw you just removed from the old wheel.
  4. Schwinn 12" Toddler and Kids' Bike Training Wheel Replacement: passo 4, imagem 1 %32
    • Realign the wheel arm with the rear bolt placement and secure it with the wheel arm bolt.
    • Replace the damaged wheel arm prior to securing it in place.
Conclusão
Brian Gibson
Membro desde: 05/24/23
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 98
