Introdução
Use this guide to remove the power supply unit.
Peças
Não são necessárias peças.
  1. Place the monitor face down.
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Remove two 11.5mm screws with a  #2 Phillips screwdriver.
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
      • There are four clips on each side, four on the top, and one on the bottom.
      • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
    • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
    • Unplug the seven connections from the power supply unit by gently pulling on them.
    • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
      • Four 6 mm Phillips screws
      • One 8 mm Phillips screw
    • Lift the power supply unit straight up to remove it from the back panel.
Conclusão
Jose Carrillo
23 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 16-56, Forte Fall 2012 Membro de Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 525
