Ir para o conteúdo principal
Sceptre X9 Komodo VII Liquid Crystal Display Replacement
O que você precisa
  1. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Stand: passo 1, imagem 1 %32
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 2, imagem 1 %32
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Board Cover: passo 3, imagem 1 %32
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 4, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 4, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 4, imagem 3 %32
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 5, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 5, imagem 2 %32
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: passo 6, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: passo 6, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, Liquid Crystal Display: passo 6, imagem 3 %32
    • Use caution when removing the connectors as they can easily break when removing.
    • Disconnect the two connectors at the top-left of the power board.
    • Disconnect the two connectors at the very bottom of the power board (pink wire).
    • Disconnect the multi-pin connector at the top of the motherboard.
    • A small flat-blade screwdriver or tweezers can be used to assist in removal of connectors.
  7. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 7, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 7, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 7, imagem 3 %32
    • Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel.
    • Carefully side the connectors through their respective openings.
    • Lif the back panel to reveal the LCD back cover.
  8. Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: passo 8, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: passo 8, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement, LCD Back Cover: passo 8, imagem 3 %32
    • Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
    • Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
  9. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 9, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 9, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 9, imagem 3 %32
    • Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover.
    • Lift the inner panel to remove it.
    • Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
  10. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 10, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 10, imagem 2 %32
    • Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover.
    • There are tabs holding down the cover. You may have to use a bit of force to pry them open.
    • A small flat-blade screwdriver can be used to pry off LCD cover.
  11. Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 11, imagem 1 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 11, imagem 2 %32 Sceptre X9 Komodo VII Liquid Crystal Display Replacement: passo 11, imagem 3 %32
    • Lift the LCD back cover to reveal the LCD screen below.
Conclusão
Uma outra pessoa concluiu este guia.
Alvin Lam
Membro desde: 09/26/12
40 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 16-56, Forte Fall 2012 Membro de Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 605
