Ir para o conteúdo principal
Sceptre X9 Komodo VII Board Cover Replacement
O que você precisa
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: passo 1, imagem 1 %32
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: passo 2, imagem 1 %32
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: passo 3, imagem 1 %32
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: passo 4, imagem 1 %32 Sceptre X9 Komodo VII Board Cover Replacement: passo 4, imagem 2 %32 Sceptre X9 Komodo VII Board Cover Replacement: passo 4, imagem 3 %32
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: passo 5, imagem 1 %32 Sceptre X9 Komodo VII Board Cover Replacement: passo 5, imagem 2 %32
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Conclusão
Uma outra pessoa concluiu este guia.
Ted Hsueh
Membro desde: 09/20/12
170 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 16-56, Forte Fall 2012 Membro de Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
Membros da 5
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 486
