Ir para o conteúdo principal
Sapphire Nitro+ RX 6800 XT SE Fan Replacement
O que você precisa
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: passo 1, imagem 1 %32
    • Unscrew the JIS000 screw securing the fan to the graphics card
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 2, imagem 1 %32
    • Lift the fan from the top and pull away from you.
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 3, imagem 1 %32
    • Clean any dust or residue present with a Q-tip damp with alcohol.
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 4, imagem 1 %32
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 5, imagem 1 %32
    • Push the fan toward you to ensure that the pins are connected.
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: passo 6, imagem 1 %32
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
Conclusão
After assembly, the fans and RGB will work like new!
Uma outra pessoa concluiu este guia.
Weston Wood
Membro desde: 10/23/23
183 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Duração total: 302
