Ir para o conteúdo principal
Sanyo-PM 8200 Motherboard Replacement
O que você precisa
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: passo 1, imagem 1 %32
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: passo 2, imagem 1 %32
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: passo 4, imagem 1 %32
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: passo 5, imagem 1 %32 Sanyo-PM 8200 Motherboard Replacement: passo 5, imagem 2 %32
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: passo 6, imagem 1 %32
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: passo 7, imagem 1 %32
    Comprar
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: passo 8, imagem 1 %32
    • Remove the motherboard from the back of the phone.
Conclusão
Michaella
Membro desde: 10/07/14
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-6, Leahy Fall 2014 Membro de USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
Membros da 6
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 385
