Ir para o conteúdo principal
Sanyo VPC-T850 Photo Array Device Replacement
O que você precisa
  1. Sanyo VPC-T850 Photo Array Device Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Photo Array Device Replacement: passo 2, imagem 1 %32
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Photo Array Device Replacement: passo 3, imagem 1 %32
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Photo Array Device Replacement: passo 4, imagem 1 %32
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: passo 5, imagem 1 %32 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: passo 5, imagem 2 %32 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: passo 5, imagem 3 %32
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 Photo Array Device Replacement: passo 6, imagem 1 %32 Sanyo VPC-T850 Photo Array Device Replacement: passo 6, imagem 2 %32
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 Photo Array Device Replacement: passo 7, imagem 1 %32
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 Photo Array Device Replacement: passo 8, imagem 1 %32 Sanyo VPC-T850 Photo Array Device Replacement: passo 8, imagem 2 %32
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 Photo Array Device Replacement: passo 9, imagem 1 %32
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 Photo Array Device Replacement, LCD Display: passo 10, imagem 1 %32
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 Photo Array Device Replacement: passo 11, imagem 1 %32
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 Photo Array Device Replacement: passo 12, imagem 1 %32
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
  13. Sanyo VPC-T850 Photo Array Device Replacement, Photo Array Device: passo 13, imagem 1 %32
    • Remove the two screws holding the photo array.
  14. Sanyo VPC-T850 Photo Array Device Replacement: passo 14, imagem 1 %32 Sanyo VPC-T850 Photo Array Device Replacement: passo 14, imagem 2 %32 Sanyo VPC-T850 Photo Array Device Replacement: passo 14, imagem 3 %32
    • Remove the foam from the top of the wire connector.
    • Gently remove the plastic connector in the same way as the previous connector of the same type.
    • Lift the connector from the side with the ribbon cable in it.
    • Using the spudger, gently push from the right side.
Conclusão
Jonathan Yau
Membro desde: 04/11/10
26 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 27-95, Amido Spring 2010 Membro de Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 2,216
