Ir para o conteúdo principal
Sanyo VPC-T850 Battery Replacement
O que você precisa
  1. Sanyo VPC-T850 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: passo 2, imagem 1 %32
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: passo 3, imagem 1 %32
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: passo 4, imagem 1 %32
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
Conclusão
Uma outra pessoa concluiu este guia.
James Robinson
Membro desde: 10/27/15
459 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 884
