Ir para o conteúdo principal
Sanyo SCP-8100 Earpiece Replacement
O que você precisa
  1. Sanyo SCP-8100 Earpiece Replacement, Earpiece: passo 1, imagem 1 %32 Sanyo SCP-8100 Earpiece Replacement, Earpiece: passo 1, imagem 2 %32
    • Open the phone and remove the four stickers that hide the four 0.5 mm screws.
    • On the bottom two, use a push pin to pull out the stickers.
    • Do this slowly and gently. You may damage the phone screen or tear the sticker.
  2. Sanyo SCP-8100 Earpiece Replacement: passo 2, imagem 1 %32
    • For the top two, use the same push pin and gently pull out the stickers.
    • These are a bit harder to pull out, so you might need to use more force. However, be gentle or else you may tear the rubber off of the sticker instead of the whole plug.
  3. Sanyo SCP-8100 Earpiece Replacement: passo 3, imagem 1 %32 Sanyo SCP-8100 Earpiece Replacement: passo 3, imagem 2 %32
    • Use the Tri-Wing Y1 screwdriver to unscrew the now uncovered four 0.5 mm screws.
  4. Sanyo SCP-8100 Earpiece Replacement: passo 4, imagem 1 %32 Sanyo SCP-8100 Earpiece Replacement: passo 4, imagem 2 %32
    • Use the opening tool to pry open the front panel.
    • You might need to use some force. If it won't budge, try the other side of the panel. You may need to pry open more than one spot to get it completely open.
    • Don't completely remove the panel, it is still connected to the phone.
  5. Sanyo SCP-8100 Earpiece Replacement: passo 5, imagem 1 %32 Sanyo SCP-8100 Earpiece Replacement: passo 5, imagem 2 %32
    • Use tweezers to detach the plastic connector.
    • With the tweezers, pull the wires from the plastic clamp.
  6. Sanyo SCP-8100 Earpiece Replacement: passo 6, imagem 1 %32 Sanyo SCP-8100 Earpiece Replacement: passo 6, imagem 2 %32
    • Use the opening tool to pull the earpiece off of the top panel.
    • You may need to use some force to take this out.
Conclusão
Irenz Afable
Membro desde: 04/15/13
57 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-41, Amido Spring 2013 Membro de Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 245
