Ir para o conteúdo principal
Sanyo Katana Front Case Replacement
O que você precisa
  1. Sanyo Katana Front Case Replacement, Screen Protector: passo 1, imagem 1 %32 Sanyo Katana Front Case Replacement, Screen Protector: passo 1, imagem 2 %32
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Front Case Replacement: passo 2, imagem 1 %32 Sanyo Katana Front Case Replacement: passo 2, imagem 2 %32
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Front Case Replacement: passo 3, imagem 1 %32 Sanyo Katana Front Case Replacement: passo 3, imagem 2 %32
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Front Case Replacement, Front Case: passo 4, imagem 1 %32 Sanyo Katana Front Case Replacement, Front Case: passo 4, imagem 2 %32 Sanyo Katana Front Case Replacement, Front Case: passo 4, imagem 3 %32
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
Conclusão
StephenYH
Membro desde: 03/11/13
20 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 12-1, Benson Spring 2013 Membro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 248
