Ir para o conteúdo principal
Sanyo Katana Eclipse X Battery Replacement
O que você precisa
  1. Sanyo Katana Eclipse X Battery Replacement, Back Panel: passo 1, imagem 1 %32 Sanyo Katana Eclipse X Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Sanyo Katana Eclipse X Battery Replacement: passo 2, imagem 1 %32
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Sanyo Katana Eclipse X Battery Replacement, Battery: passo 3, imagem 1 %32
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Sanyo Katana Eclipse X Battery Replacement: passo 4, imagem 1 %32
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
Conclusão
Thomas Scaggs
Membro desde: 10/15/12
209 Reputação
2 Guias de autoria
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 396
