Introdução
This guide removes the camera after reaching it by removing the screen and front case of the phone. Though the casing can be difficult to remove, the camera itself requires minimal effort to replace.
Ferramentas
Peças
Não são necessárias peças.
With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Use the spudger to pry off the front case from the left and right sides of the device.
Once it has popped off, pull the casing apart with fingers.
Use a Tri-wing Y0 screwdriver to remove the 4.4mm screw.
Use fingers to remove the strip.
