Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide the entire back case will be removed from the device, including the battery and battery cover. A screwdriver will be used in during the guide.
O que você precisa
Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
While holding down the button, pull cover off with other hand.
Using a spudger, remove the four rubber coverings on the lower back plate.
