Ir para o conteúdo principal
Sansa e260R Scroll Wheel Replacement
O que você precisa
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: passo 1, imagem 1 %32
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: passo 3, imagem 1 %32
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: passo 4, imagem 1 %32
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: passo 5, imagem 1 %32
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: passo 6, imagem 1 %32
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: passo 7, imagem 1 %32 Sansa e260R Scroll Wheel Replacement: passo 7, imagem 2 %32
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: passo 8, imagem 1 %32 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: passo 8, imagem 2 %32
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: passo 9, imagem 1 %32 Sansa e260R Scroll Wheel Replacement: passo 9, imagem 2 %32
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: passo 10, imagem 1 %32
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
Conclusão
6 outras pessoas executaram este guia.
JenniferW
Membro desde: 01/31/12
194 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-15, Maness Winter 2012 Membro de Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Membros
Autoria de 5 guias
Um comentário
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 3,356
