Peças
Nenhum componente especificado.
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
5 outras pessoas concluíram este guia.
Um comentário
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
