Ir para o conteúdo principal
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: passo 1, imagem 1 %32
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 2, imagem 1 %32
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 3, imagem 1 %32
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 4, imagem 1 %32
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 5, imagem 1 %32
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 6, imagem 1 %32 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: passo 6, imagem 2 %32
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Conclusão
Caycie Pascual
Membro desde: 09/26/12
1 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 16-58, Forte Fall 2012 Membro de Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 2,803
