Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to remove the back wheels and axle of a Sanitaire SC684 Vacuum and replace them. For this you will need a replacement back wheel and axle part for a Sanitaire SC684. The wheels come attached with the axle and are removed and replaced together.
O que você precisa
Lay the vacuum on its side.
Remove the two screws with the Phillips #1 screwdriver that are securing the axle of the back wheels.
Repeat for the other wheel.
