Ir para o conteúdo principal
Sandal Brooch Replacement
O que você precisa
  1. Sandal Brooch Replacement, Brooch: passo 1, imagem 1 %32 Sandal Brooch Replacement, Brooch: passo 1, imagem 2 %32 Sandal Brooch Replacement, Brooch: passo 1, imagem 3 %32
    • Unwind about 10" of thread. Cut and thread through the needle. Tie a double knot at the end of the thread.
  2. Sandal Brooch Replacement: passo 2, imagem 1 %32 Sandal Brooch Replacement: passo 2, imagem 2 %32
    • The threads and empty holes show exactly where to attach the shoe ornament.
    • Cut off the old threads.
  3. Sandal Brooch Replacement: passo 3, imagem 1 %32 Sandal Brooch Replacement: passo 3, imagem 2 %32
    • Start the threaded needle on the upper side of the sandal.
    • The ornament will hide the knot.
    • If pushing the needle through the sandal strap is difficult, you might try turning the sandal at an angle and using your flat surface as a pressing point.
  4. Sandal Brooch Replacement: passo 4, imagem 1 %32
    • Pull the thread through the ornament's opening.
    • Be careful—needles are sharp!
  5. Sandal Brooch Replacement: passo 5, imagem 1 %32 Sandal Brooch Replacement: passo 5, imagem 2 %32 Sandal Brooch Replacement: passo 5, imagem 3 %32
    • Pull the thread down and through the sandal straps.
    • Repeat the process, catching the ornament in a variety of places to anchor several sides.
  6. Sandal Brooch Replacement: passo 6, imagem 1 %32 Sandal Brooch Replacement: passo 6, imagem 2 %32
    • Pull the thread so that the ornament is tight against the sandal.
    • Remember to beware of that sharp needle!
  7. Sandal Brooch Replacement: passo 7, imagem 1 %32
    • Run the needle back through the sandal strap, then tie a knot at the base of the thread.
    • Double the knot before using your scissors to cut the thread.
    • Cut the thread just above the knot.
    • Be careful—scissors are sharp.
  8. Sandal Brooch Replacement: passo 8, imagem 1 %32
    • Completed sandal—ready to wear!
Conclusão
Enjoy wearing the sandals!
KaC
Membro desde: 08/27/23
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 161
