Ir para o conteúdo principal
SanDisk Sansa C250 Rear Case Cover Replacement
O que você precisa
  1. SanDisk Sansa C250 Rear Case Cover Replacement, Battery Cover: passo 1, imagem 1 %32
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Rear Case Cover Replacement: passo 2, imagem 1 %32
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Rear Case Cover Replacement, Battery: passo 3, imagem 1 %32
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Rear Case Cover Replacement: passo 4, imagem 1 %32
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Rear Case Cover Replacement: passo 5, imagem 1 %32
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Rear Case Cover Replacement, Rear Case Cover: passo 6, imagem 1 %32
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Rear Case Cover Replacement: passo 7, imagem 1 %32
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Rear Case Cover Replacement: passo 8, imagem 1 %32
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Rear Case Cover Replacement: passo 9, imagem 1 %32
    • The rear case cover can now be separated from the device.
Conclusão
Nicolas Coffey
Membro desde: 01/27/12
43 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-30, Amido Winter 2012 Membro de Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 871
