Ir para o conteúdo principal
SanDisk Sansa C250 Internal Battery Replacement
O que você precisa
  1. SanDisk Sansa C250 Internal Battery Replacement, Battery Cover: passo 1, imagem 1 %32 SanDisk Sansa C250 Internal Battery Replacement, Battery Cover: passo 1, imagem 2 %32
    • Slide the back cover toward the top of the device with your thumb to remove it.
  2. SanDisk Sansa C250 Internal Battery Replacement, Battery: passo 2, imagem 1 %32
    • Wedge your plastic pry tool under the edge of the battery.
  3. SanDisk Sansa C250 Internal Battery Replacement: passo 3, imagem 1 %32 SanDisk Sansa C250 Internal Battery Replacement: passo 3, imagem 2 %32
    • Gently lift up with the pry tool. The battery should lift up and out.
  4. SanDisk Sansa C250 Internal Battery Replacement, Rear Case Cover: passo 4, imagem 1 %32
    • Using a Phillips head screwdriver, remove the two black .265" screws at the base of the device.
  5. SanDisk Sansa C250 Internal Battery Replacement: passo 5, imagem 1 %32 SanDisk Sansa C250 Internal Battery Replacement: passo 5, imagem 2 %32
    • Locate the two plastic arms of the case cover, near the middle of the device.
    • Using the plastic ply tool, pry up the two arms of the case to free them from the sides.
  6. SanDisk Sansa C250 Internal Battery Replacement: passo 6, imagem 1 %32 SanDisk Sansa C250 Internal Battery Replacement: passo 6, imagem 2 %32
    • Slide the rear case cover toward the top of the device with your thumb to release it, and remove it from the device.
  7. SanDisk Sansa C250 Internal Battery Replacement, Front Case Cover: passo 7, imagem 1 %32
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  8. SanDisk Sansa C250 Internal Battery Replacement: passo 8, imagem 1 %32
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  9. SanDisk Sansa C250 Internal Battery Replacement: passo 9, imagem 1 %32
    • Open the case cover starting on the side most distance from the buttons.
  10. SanDisk Sansa C250 Internal Battery Replacement: passo 10, imagem 1 %32
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  11. SanDisk Sansa C250 Internal Battery Replacement: passo 11, imagem 1 %32
    • You can now safely remove the front case cover from the device.
  12. SanDisk Sansa C250 Internal Battery Replacement, Internal Battery: passo 12, imagem 1 %32
    • CAUTION: If using a fingernail, be careful not to hurt yourself on the connector.
    • Using a spudger or flat tool, lift the battery up and away from the board, taking note of its orientation.
  13. SanDisk Sansa C250 Internal Battery Replacement: passo 13, imagem 1 %32
    • Desolder the connectors on both sides of the battery to remove it.
    • Resolder on a new Panasonic 6Y3 micro cell battery, taking care to orient it correctly as noted in the previous step.
    • Bend the battery back so that it's flat against the board.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Burke
Membro desde: 01/23/12
58 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-30, Amido Winter 2012 Membro de Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 3,165
