Ir para o conteúdo principal
SanDisk Sansa C250 Headphone Jack Replacement
O que você precisa
  1. SanDisk Sansa C250 Headphone Jack Replacement, Battery Cover: passo 1, imagem 1 %32
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Headphone Jack Replacement: passo 2, imagem 1 %32
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Headphone Jack Replacement, Battery: passo 3, imagem 1 %32
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Headphone Jack Replacement: passo 4, imagem 1 %32
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Headphone Jack Replacement: passo 5, imagem 1 %32
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Headphone Jack Replacement, Rear Case Cover: passo 6, imagem 1 %32
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Headphone Jack Replacement: passo 7, imagem 1 %32
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Headphone Jack Replacement: passo 8, imagem 1 %32
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Headphone Jack Replacement: passo 9, imagem 1 %32
    • The rear case cover can now be separated from the device.
  10. SanDisk Sansa C250 Headphone Jack Replacement, Front Case Cover: passo 10, imagem 1 %32
    • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  11. SanDisk Sansa C250 Headphone Jack Replacement: passo 11, imagem 1 %32
    • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
    • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
  12. SanDisk Sansa C250 Headphone Jack Replacement: passo 12, imagem 1 %32
    • Open the case cover starting on the side most distance from the buttons.
  13. SanDisk Sansa C250 Headphone Jack Replacement: passo 13, imagem 1 %32
    • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  14. SanDisk Sansa C250 Headphone Jack Replacement: passo 14, imagem 1 %32
    • You can now safely remove the front case cover from the device.
  15. SanDisk Sansa C250 Headphone Jack Replacement, Headphone Jack: passo 15, imagem 1 %32
    • CAUTION: Do not scrape the spludger along the top of the motherboard or you may damage the circuitry.
    • Using a spudger, carefully pry the motherboard out of the case.
  16. SanDisk Sansa C250 Headphone Jack Replacement: passo 16, imagem 1 %32 SanDisk Sansa C250 Headphone Jack Replacement: passo 16, imagem 2 %32
    • Flip the device over. In one corner, there is a large black component extending past the side of the device. This is the headphone jack.
    • Using a soldering iron, desolder the four points at which the headphone jack connects to the motherboard.
  17. SanDisk Sansa C250 Headphone Jack Replacement: passo 17, imagem 1 %32
    • Rotate the device
  18. SanDisk Sansa C250 Headphone Jack Replacement: passo 18, imagem 1 %32 SanDisk Sansa C250 Headphone Jack Replacement: passo 18, imagem 2 %32
    • Resolder the new headphone jack to the motherboard, being careful that it is fully attached and in place.
    • Dimensions for headphone jack: 0.230" by 0.541" 1/8" diameter
    • The red box displays the newly installed headphone jack.
Conclusão
Ryan Burke
Membro desde: 01/23/12
55 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-30, Amido Winter 2012 Membro de Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
Membros da 3
Autoria de 6 guias
Um comentário
Sometimes the problem isn't that you need to solder a new jack on but that the jack has become detached from the board or worse the board has started to flake apart (the pad has detached from the board).
So get out your volt meter before you remove the old jack and test to make sure it's the jack that is the problem. My experience is that it is rarely the jack (I've fixed several of these).
There are a couple places on the board where you can solder wires onto if the pads become detached. Just be sure to glue the jack down since the pads aren't anchoring it now (so you don't put added strain on the remaining pads).
Strife Onizuka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 2,749
