Ir para o conteúdo principal
Samsung YP-P3 Buttons Replacement
O que você precisa
  1. Samsung YP-P3 Buttons Replacement, Case Backplate: passo 1, imagem 1 %32
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Buttons Replacement: passo 2, imagem 1 %32
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Buttons Replacement: passo 3, imagem 1 %32 Samsung YP-P3 Buttons Replacement: passo 3, imagem 2 %32
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
  4. Samsung YP-P3 Buttons Replacement, Printed Circuit Board: passo 4, imagem 1 %32 Samsung YP-P3 Buttons Replacement, Printed Circuit Board: passo 4, imagem 2 %32 Samsung YP-P3 Buttons Replacement, Printed Circuit Board: passo 4, imagem 3 %32
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
  5. Samsung YP-P3 Buttons Replacement: passo 5, imagem 1 %32 Samsung YP-P3 Buttons Replacement: passo 5, imagem 2 %32
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
  6. Samsung YP-P3 Buttons Replacement: passo 6, imagem 1 %32
    • Disconnect the battery connector, and then lift the circuit board up.
  7. Samsung YP-P3 Buttons Replacement: passo 7, imagem 1 %32
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
  8. Samsung YP-P3 Buttons Replacement, Battery: passo 8, imagem 1 %32
    • Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
  9. Samsung YP-P3 Buttons Replacement, Touch Screen: passo 9, imagem 1 %32 Samsung YP-P3 Buttons Replacement, Touch Screen: passo 9, imagem 2 %32 Samsung YP-P3 Buttons Replacement, Touch Screen: passo 9, imagem 3 %32
    • Remove the six screws (Phillips #000, 2.3 mm long) holding the screen frame to the front of the case. As the picture shows, one of them is hidden under the black speaker/rumble assembly.
  10. Samsung YP-P3 Buttons Replacement: passo 10, imagem 1 %32 Samsung YP-P3 Buttons Replacement: passo 10, imagem 2 %32
    • To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger.
    • The assembly is glued to the back of the screen, so the assembly may not move at first. Be patient and careful. Do not pry too hard, or you may break the assembly.
  11. Samsung YP-P3 Buttons Replacement: passo 11, imagem 1 %32
    • Lift the screen out from the case.
  12. Samsung YP-P3 Buttons Replacement, Buttons: passo 12, imagem 1 %32 Samsung YP-P3 Buttons Replacement, Buttons: passo 12, imagem 2 %32
    • The buttons, built-in speaker, and rumble device are all contained in a black plastic assembly. This assembly simply snaps into place at the top of the case. Lift up gently to remove it from its place.
Conclusão
Equipe
1Comentário do guia
This is terrific, but who makes a 3”, 272x480 pixel lcd screen and/or touchpanel for the samsung? Is this the same screen hardware as on the P2?
Kevin Moorman - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 627
