Ir para o conteúdo principal
Samsung WB850F Screen Replacement
O que você precisa
  1. Samsung WB850F Screen Replacement, Screen: passo 1, imagem 1 %32 Samsung WB850F Screen Replacement, Screen: passo 1, imagem 2 %32 Samsung WB850F Screen Replacement, Screen: passo 1, imagem 3 %32
    • First remove the battery and SD Card
    • Then use the screwdriver to remove the 6 screws that need to be removed to take off the outer case.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side (near the HDMI port).
    • 2 screws are located on the right side (opposite side of the HDMI port).
  2. Samsung WB850F Screen Replacement: passo 2, imagem 1 %32
    • Once the screws are removed, use the blue opening tool to open the back case from the sides - it should come off easily.
  3. Samsung WB850F Screen Replacement: passo 3, imagem 1 %32 Samsung WB850F Screen Replacement: passo 3, imagem 2 %32
    • Use the screwdriver to remove the small silver screw holding down the control panel (located on the bottom right next to the screen).
    • Use the blue opening tool to lift up the control panel from where the screw was just removed.
  4. Samsung WB850F Screen Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to gently pull the yellow control board ribbon cable out of its connector.
    • The display cable stands straight up and pops out easily. Pull up on it to remove the screen from the camera.
  5. Samsung WB850F Screen Replacement: passo 5, imagem 1 %32
    • Connect the new screen by gently pressing the display cable on to its connector (on the motherboard).
    • When reinserting the control board, make sure the top of the control board is under the lip before screwing it in place.
Conclusão
Jousling Vazquez
Membro desde: 02/08/16
431 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
Membros da 4
Autoria de 8 guias
2 comentários
I previously mentioned that I had a sticky substance seeping from my camera. I spent quite a long time, using acetone to remove this fluid stuff from the LCD and the clear screen which was stuck to the LCD. It was not an easy task because of the quick evaporation of the acetone. Now, must I stick the LCD and the part/clear lens together? If so, with what glue? The second part to my question is that there was a second plate (?) with a rubbery surface on one side and I did not notice which side faces the lens because it fell out before I noticed it, rubber or plain metal? Any help will be appreciated. :-(
Ian Blyth - Responder
Is it normal from such a renowned company? I even got some instability in installed programs.
Hon Fah Cheung -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 649
