O que você precisa
Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
2 screws are located on the bottom.
2 screws are located on the left side. (HDMI port)
2 screws are located on the right side of the camera. (Opposite HDMI side)
Remove the two screws.
Gently pry open metal case using Plastic tool openers.
2Comentários do guia
hi I have problem...could you please help me with my camera samsung wb850f
I am forward to hearing from you....
