Ir para o conteúdo principal
Samsung WB850F Lens Assembly Replacement
O que você precisa
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, imagem 1 %32 Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, imagem 2 %32 Samsung WB850F Lens Assembly  Replacement, Control Panel: passo 1, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: passo 2, imagem 1 %32
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: passo 3, imagem 1 %32 Samsung WB850F Lens Assembly  Replacement: passo 3, imagem 2 %32
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, imagem 1 %32 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, imagem 2 %32 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: passo 4, imagem 3 %32
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: passo 5, imagem 1 %32 Samsung WB850F Lens Assembly  Replacement: passo 5, imagem 2 %32
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: passo 6, imagem 1 %32
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Conclusão
Jousling Vazquez
Membro desde: 02/08/16
431 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Membros
Autoria de 8 guias
2Comentários do guia
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Responder
I am forward to hearing from you....
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 1,704
