Ir para o conteúdo principal
Samsung WB850F Control Panel Replacement
O que você precisa
  1. Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 1 %32 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 2 %32 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: passo 2, imagem 1 %32
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: passo 3, imagem 1 %32 Samsung WB850F Control Panel Replacement: passo 3, imagem 2 %32
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
Conclusão
Jousling Vazquez
Membro desde: 02/08/16
431 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
Membros da 4
Autoria de 8 guias
Um comentário
Only problem .. Where can I buy a replacement control panel.
D Traynor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 729
