Ir para o conteúdo principal
Samsung WB350F Rear Case Replacement
O que você precisa
  1. Samsung WB350F Rear Case Replacement, Rear Case: passo 1, imagem 1 %32 Samsung WB350F Rear Case Replacement, Rear Case: passo 1, imagem 2 %32 Samsung WB350F Rear Case Replacement, Rear Case: passo 1, imagem 3 %32
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: passo 2, imagem 1 %32 Samsung WB350F Rear Case Replacement: passo 2, imagem 2 %32 Samsung WB350F Rear Case Replacement: passo 2, imagem 3 %32
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: passo 3, imagem 1 %32 Samsung WB350F Rear Case Replacement: passo 3, imagem 2 %32 Samsung WB350F Rear Case Replacement: passo 3, imagem 3 %32
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: passo 4, imagem 1 %32
    • Remove the plastic casing, exposing the inner workings of the camera.
Conclusão
Zachary Bourgault
Membro desde: 03/04/16
101 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 803
