Ir para o conteúdo principal
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung WB350F Battery Replacement, Battery: passo 1, imagem 2 %32 Samsung WB350F Battery Replacement, Battery: passo 1, imagem 3 %32
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: passo 2, imagem 1 %32
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
Conclusão
Taylor Joubert
Membro desde: 03/04/16
273 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G2
Membros da 4
Autoria de 8 guias
Um comentário
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 1,756
