Ir para o conteúdo principal
Samsung WB150F Memory Card Replacement
  1. Samsung WB150F Memory Card Replacement, Memory Card: passo 1, imagem 1 %32
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: passo 2, imagem 1 %32 Samsung WB150F Memory Card Replacement: passo 2, imagem 2 %32
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
  3. Samsung WB150F Memory Card Replacement: passo 3, imagem 1 %32
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
Conclusão
Equipe
2Comentários do guia
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Responder Compartilhar
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 71
Ao todo: 1,464
