Introdução
Use this guide to remove the motherboard of your device.
O que você precisa
On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
Fan A is located on top of the motherboard and is screwed into a stand by two 6.5mm screws. The stand is also connected to the motherboard.
The motherboard is in the middle of the device and has all wires and connections of the device components running to it. The fan identified as fan A is located on top of it and must be removed first.
Uma outra pessoa concluiu este guia.
