Ir para o conteúdo principal
Samsung U28E510 Motherboard Replacement
O que você precisa
  1. Samsung U28E510 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Samsung U28E510 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Samsung U28E510 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: passo 2, imagem 1 %32 Samsung U28E510 Motherboard Replacement: passo 2, imagem 2 %32
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: passo 3, imagem 1 %32 Samsung U28E510 Motherboard Replacement: passo 3, imagem 2 %32
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: passo 4, imagem 1 %32 Samsung U28E510 Motherboard Replacement: passo 4, imagem 2 %32
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
Conclusão
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3 outras pessoas executaram este guia.
Melina
Membro desde: 01/22/18
154 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G1, Banghart Winter 2018 Membro de Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 1,378
