Ir para o conteúdo principal
Samsung U28E510 Jog Button Replacement
O que você precisa
  1. Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, imagem 1 %32 Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, imagem 2 %32 Samsung U28E510 Jog Button Replacement, Jog Button: passo 1, imagem 3 %32
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: passo 2, imagem 1 %32 Samsung U28E510 Jog Button Replacement: passo 2, imagem 2 %32
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: passo 3, imagem 1 %32
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Conclusão
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 outras pessoas executaram este guia.
Jake Ritter
Membro desde: 01/22/18
106 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G1, Banghart Winter 2018 Membro de Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
Membros da 4
Autoria de 6 guias
5 comentários
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Responder
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Responder
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Responder
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 60
Duração total: 6,677
