Introdução
All you need for this guide is the will to fix your camera. Enjoy!
O que você precisa
Check for debris and dust around the power button to make sure it's clean.
If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
Now carefully pry open the back casing with the ifixit plastic opening tool.
