Ir para o conteúdo principal
Samsung TFT Color YP-T7J The Screen Replacement
O que você precisa
  1. Samsung TFT Color YP-T7J The Screen Replacement, The Back Cover: passo 1, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement, The Back Cover: passo 1, imagem 2 %32
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Screen Replacement: passo 2, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 2, imagem 2 %32
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Screen Replacement: passo 3, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 3, imagem 2 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 3, imagem 3 %32
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Screen Replacement, The Battery: passo 4, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement, The Battery: passo 4, imagem 2 %32
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Screen Replacement: passo 5, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 5, imagem 2 %32
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 2 %32 Samsung TFT Color YP-T7J The Screen Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: passo 6, imagem 3 %32
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J The Screen Replacement, The Front Cover: passo 7, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement, The Front Cover: passo 7, imagem 2 %32
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J The Screen Replacement: passo 8, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 8, imagem 2 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 8, imagem 3 %32
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J The Screen Replacement: passo 9, imagem 1 %32
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J The Screen Replacement: passo 10, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 10, imagem 2 %32
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J The Screen Replacement, The Screen: passo 11, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement, The Screen: passo 11, imagem 2 %32
    • Place the pry tool between the plastic housing around the LCD screen, and the mother board.
    • Gently separate the screen housing from the mother board
    • CAUTION: The screen is still attached to the mother board via another electric ribbon.
  12. Samsung TFT Color YP-T7J The Screen Replacement: passo 12, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 12, imagem 2 %32
    • Using a plastic pry tool to flip up the lip, which connects the electric ribbon to the mother board.
  13. Samsung TFT Color YP-T7J The Screen Replacement: passo 13, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 13, imagem 2 %32
    • Place the pry tool between the LCD screen and the white housing unit
    • Gently separate the two.
  14. Samsung TFT Color YP-T7J The Screen Replacement: passo 14, imagem 1 %32 Samsung TFT Color YP-T7J The Screen Replacement: passo 14, imagem 2 %32
    • Insert the new screen into the white unit.
    • Connect the LCD screen to the mother board by inserting the electric ribbon into its port, and closing the lip.
Conclusão
Jason Farr
Membro desde: 10/21/13
353 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 14-8, Benson Fall 2013 Membro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 413
