Ir para o conteúdo principal
Samsung Sway Rear Cover Replacement
O que você precisa
  1. Samsung Sway Rear Cover Replacement, Rear cover: passo 1, imagem 1 %32
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: passo 2, imagem 1 %32 Samsung Sway Rear Cover Replacement: passo 2, imagem 2 %32
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: passo 3, imagem 1 %32 Samsung Sway Rear Cover Replacement: passo 3, imagem 2 %32
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: passo 4, imagem 1 %32
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: passo 6, imagem 1 %32
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
Conclusão
Chris Rush
Membro desde: 06/27/13
306 Reputação
Autoria de 3 guias
Equipe
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 283
