Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using your thumb(s) slide the cover up to remove
Remove the battery by using your finger either in the upper left or right corner
Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
Unscrew the two .4 cm Phillips head screws from under the Samsung logo
Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off. Being careful of the side buttons that pop off.
Grasp the sides of the motherboard and gently rock back and forth . This is due to the sticky tape that is on the battery
Disconnect the black serial cable from the mother board.
Uma outra pessoa concluiu este guia.
