Ir para o conteúdo principal
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, imagem 2 %32 Samsung Spex SCH-R210 Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: passo 2, imagem 1 %32
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: passo 3, imagem 1 %32
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Conclusão
Austin
Membro desde: 07/11/13
201 Reputação
Autoria de 2 guias
Equipe
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 331
