Introdução
We will show you the easiest way to remove the Samsung Spex SCH-R210 battery and replace it with a new one. No tools required!
Lay the phone on its front side so the back is visible.
Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
Slide the cover down from the phone to remove it. Set the cover aside.
Conclusão
