Ir para o conteúdo principal
Samsung Solstice SIM Card Replacement
  1. Samsung Solstice SIM Card Replacement, Remove the back cover: passo 1, imagem 1 %32 Samsung Solstice SIM Card Replacement, Remove the back cover: passo 1, imagem 2 %32
    • Remove the back cover by sliding the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice SIM Card Replacement, Removing existing SIM Card: passo 2, imagem 1 %32 Samsung Solstice SIM Card Replacement, Removing existing SIM Card: passo 2, imagem 2 %32 Samsung Solstice SIM Card Replacement, Removing existing SIM Card: passo 2, imagem 3 %32
    • Locate the SIM Card slot directly above the battery and below the phone camera
    • Place your thumb on the SIM Card in the slot, press down gently and slide the card away from the slot, until it comes out of the slot entirely
  3. Samsung Solstice SIM Card Replacement, Set SIM Card aside: passo 3, imagem 1 %32
    • Once you have removed the SIM card, set it aside from the phone.
Conclusão
Colton Glyder
Membro desde: 09/05/14
301 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 272
