Ir para o conteúdo principal
Samsung SmartCam HD Speaker Replacement
O que você precisa
  1. Samsung SmartCam HD Speaker Replacement, Speaker: passo 1, imagem 1 %32 Samsung SmartCam HD Speaker Replacement, Speaker: passo 1, imagem 2 %32 Samsung SmartCam HD Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: passo 2, imagem 1 %32 Samsung SmartCam HD Speaker Replacement: passo 2, imagem 2 %32
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: passo 3, imagem 1 %32 Samsung SmartCam HD Speaker Replacement: passo 3, imagem 2 %32 Samsung SmartCam HD Speaker Replacement: passo 3, imagem 3 %32
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: passo 4, imagem 1 %32 Samsung SmartCam HD Speaker Replacement: passo 4, imagem 2 %32
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: passo 5, imagem 1 %32 Samsung SmartCam HD Speaker Replacement: passo 5, imagem 2 %32 Samsung SmartCam HD Speaker Replacement: passo 5, imagem 3 %32
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: passo 6, imagem 1 %32 Samsung SmartCam HD Speaker Replacement: passo 6, imagem 2 %32 Samsung SmartCam HD Speaker Replacement: passo 6, imagem 3 %32
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
Conclusão
Pranab Baidya
Membro desde: 06/27/17
104 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G1, Liner Summer 2017 Membro de UW Tacoma, Team S1-G1, Liner Summer 2017
UWT-LINER-SU17S1G1
Membros da 4
Autoria de 6 guias
Um comentário
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 582
