Ir para o conteúdo principal
Samsung SmartCam HD Pro Speaker Replacement
O que você precisa
  1. Samsung SmartCam HD Pro Speaker Replacement, Casing: passo 1, imagem 1 %32
    • Locate a small opening around the front panel of the camera.
  2. Samsung SmartCam HD Pro Speaker Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung SmartCam HD Pro Speaker Replacement: passo 3, imagem 1 %32
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung SmartCam HD Pro Speaker Replacement: passo 4, imagem 1 %32
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung SmartCam HD Pro Speaker Replacement: passo 5, imagem 1 %32
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung SmartCam HD Pro Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Insert plastic opening tool below the plastic speaker cover on the inside of the removed front panel of the device.
  7. Samsung SmartCam HD Pro Speaker Replacement: passo 7, imagem 1 %32
    • Push the two tabs holding the speaker cover on, while prying it up.
  8. Samsung SmartCam HD Pro Speaker Replacement: passo 8, imagem 1 %32
    • Pull out the speaker which is now loosely resting in its plastic housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 243
