Introdução
The WiFi card enables you to access the internet wirelessly and on-the-go, instead of being connected to an Ethernet cable. If your WiFi card is broken or malfunctioning, it will need to be replaced.
O que você precisa
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Remove the back panel of the laptop.
Uma outra pessoa concluiu este guia.
3 comentários
It does. I just added the AC-7620 to my NP900X4C. And it works perfectly! Speed difference is huge. Went from 70 to 80 mbps to 250 mbsp on a 300 mbps connection. USB dongles didn't make much of a difference. It you have an older 900x give this a try.
Also if you do a clean install of Windows 10, the bluetooth driver doesn't install automatically. Here was the last version released by Intel.
Heron -
