Introdução
The RAM, or memory, has a significant effect on your laptop’s performance, so if you’re having issues, you may want to replace your RAM or upgrade it.
O que você precisa
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Use an iFixit opening tool to carefully remove the back panel from the laptop.
Quase terminado!
Conclusão
