Ir para o conteúdo principal
Samsung Series 9 NP900X4B-A02 Speaker Replacement
O que você precisa
  1. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: passo 1, imagem 1 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 2, imagem 1 %32
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 3, imagem 1 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 4, imagem 1 %32
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: passo 5, imagem 1 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: passo 5, imagem 2 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 6, imagem 1 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 6, imagem 2 %32 Samsung Series 9 NP900X4B-A02 Speaker Replacement: passo 6, imagem 3 %32
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
Conclusão
Brady Hildreth
Membro desde: 11/04/19
361 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G4, Henning Fall 2019 Membro de IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 654
