Ir para o conteúdo principal
Samsung Series 9 NP900X4B-A02 I/O PCB Replacement
O que você precisa
  1. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: passo 1, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: passo 1, imagem 2 %32
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 2, imagem 1 %32
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 3, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 4, imagem 1 %32
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: passo 5, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: passo 5, imagem 2 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: passo 5, imagem 3 %32
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 6, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 6, imagem 2 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 6, imagem 3 %32
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
  7. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: passo 7, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: passo 7, imagem 2 %32
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  8. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 8, imagem 1 %32
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  9. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 9, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  10. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 10, imagem 1 %32
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
  11. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, I/O PCB: passo 11, imagem 1 %32
    • Remove the five 2.5 mm Phillips #00 screws securing the I/O PCB.
  12. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 12, imagem 1 %32
    • Lift and pull the SSD from the board.
  13. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 13, imagem 1 %32
    • Disconnect the black press fit connector by gently lifting up.
  14. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 14, imagem 1 %32 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: passo 14, imagem 2 %32
    • Lift the right side of the I/O PCB and pull to the right to remove it from the laptop casing.
Conclusão
Brady Hildreth
Membro desde: 11/04/19
361 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G4, Henning Fall 2019 Membro de IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 278
