Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
Identify RAM slot on the top right side of the battery.
Place your fingernail or a pry tool in between the metal retention bars and the RAM unit.
Use your fingernail or pry tool to pull outward on the retention bars.
Pull up on the RAM unit at a 45 degree angle to release it from the retention bars.
4 outras pessoas executaram este guia.
