Ir para o conteúdo principal
Samsung Series 5 UltraTouch Battery Replacement
O que você precisa
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: passo 1, imagem 1 %32 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: passo 1, imagem 2 %32
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: passo 2, imagem 1 %32 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: passo 2, imagem 2 %32
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: passo 3, imagem 1 %32 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: passo 3, imagem 2 %32
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: passo 4, imagem 1 %32 Samsung Series 5 UltraTouch Battery Replacement: passo 4, imagem 2 %32
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: passo 5, imagem 1 %32
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: passo 6, imagem 1 %32
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: passo 7, imagem 1 %32
    • Remove the battery from the laptop.
Conclusão
14 outras pessoas executaram este guia.
Timothy
Membro desde: 01/30/15
1.579 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-3, Watkins Winter 2015 Membro de USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
Membros da 4
Autoria de 5 guias
2 comentários
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Responder
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Duração total: 26,902
