Ir para o conteúdo principal
Samsung Series 5 3G Chromebook WWAN board Replacement
O que você precisa
  1. Samsung Series 5 3G Chromebook WWAN board Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Series 5 3G Chromebook WWAN board Replacement, Back Cover: passo 1, imagem 2 %32
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook WWAN board Replacement: passo 2, imagem 1 %32 Samsung Series 5 3G Chromebook WWAN board Replacement: passo 2, imagem 2 %32
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook WWAN board Replacement: passo 3, imagem 1 %32 Samsung Series 5 3G Chromebook WWAN board Replacement: passo 3, imagem 2 %32
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook WWAN board Replacement, WWAN board: passo 4, imagem 1 %32 Samsung Series 5 3G Chromebook WWAN board Replacement, WWAN board: passo 4, imagem 2 %32 Samsung Series 5 3G Chromebook WWAN board Replacement, WWAN board: passo 4, imagem 3 %32
    • Remove the single Phillip screw
    • Disconnect the WWAN antennas from the I/O board
    • Remove the WWAN board from the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 690
